uniprot_id_mapping package
Submodules
uniprot_id_mapping.cache module
Cache management.
class uniprot_id_mapping.cache.CacheManager(cache_dir=None)[source]
Bases: object
Cache manager.
NAME = 'uniprot_id_mapping'[source]
__init__(cache_dir=None)[source]
Parameters:
cache_dir – An optional path to a cache directory. If None, the standard XDG path will be used.
property cache_dir[source]
The cache directory as a pathlib.Path object.
clear()[source]
Remove the cache directory.
get_path(subpath, is_dir=False)[source]
Get the full path to a subdirectory of the cache directory.
Parameters:
  • subpath – The subpath within the cache directory.
  • is_dir – If True, treat the subpath as a directory.
Returns:
The full path to the given subpath. The parent directory will be created if missing. If is_dir is True, so will the final path component.
uniprot_id_mapping.exception module
Custom exceptions.
exception uniprot_id_mapping.exception.UniprotIdMappingException[source]
Bases: Exception
Base exception class for custom exceptions raised by this package.
uniprot_id_mapping.id_mapper module
Map IDs via the UniProt ID mapping service: https://www.uniprot.org/help/id_mapping
class uniprot_id_mapping.id_mapper.IdMapper(cache_man: CacheManager = None, timeout: float = 10)[source]
Bases: object
Wrapper around the UniProt ID mapping service with local caching.
EMPTY_PLACEHOLDER = ''[source]
__init__(cache_man: CacheManager = None, timeout: float = 10)[source]
Parameters:
  • cache_man – A configured CacheManager instance.
  • timeout – Connection timeout for remote requests, in seconds.
property fields[source]
The available databases between which one can map IDs.
property local_database_path[source]
The path to the cached database.
map_ids(db_from, db_to, identifiers, refresh_missing=False)[source]
Map identifiers from one database to another.
Parameters:
  • db_from – The database from which to map the identifiers.
  • db_to – The database to which to map the identifiers.
  • identifiers – The identifiers in db_from that should be mapped to db_to.
  • refresh_missing – If True, check the server if previously missing values have been added since the last query.
Returns:
A dict mapping the found identifiers in db_from to identifiers in db_to.
Raises:
ValueError – Invalid arguments for db_from or db_to.
exception uniprot_id_mapping.id_mapper.IdMapperError[source]
Bases: UniprotIdMappingException
Custom exception raised by IdMapper.
uniprot_id_mapping.main module
Map IDs between databases using UniProt’s ID Mapping service.
uniprot_id_mapping.main.main(pargs)[source]
Main.
Parameters:
pargs – The parsed arguments.
uniprot_id_mapping.main.parse_args(args=None)[source]
Parse command-line arguments.
uniprot_id_mapping.main.run_main(args=None)[source]
Wrapper around main with exception handling.
Module contents
Package stub.
class uniprot_id_mapping.IdMapper(cache_man: CacheManager = None, timeout: float = 10)[source]
Bases: object
Parameters:
Parameters:
Returns:
Raises:
